Menu
Quick Eze Links
2023 TOFT 10-18 TON 06B 24-inch Bucket Hydraulic Grapple/Thumb
Posted Date: Jan 30th, 2025 at 04:09 AM
0.0 star
Price: 6000.00
Unused 2023 TOFT 06B 24-inch Bucket with Hydraulic Grapple/Thumb
70 mm Pins, fits 10 - 18 Ton Excavators, S/N: TOFTTB23624
Pin bushing system allows up to 11 1/2 inches between ears but can bush up or down to fit any pin grabber coupler.
Unused 2023 TOFT 06B Bucket with Thumb Grapple built in that works through the entire bucket rotation.
Extreme duty bucket perfect for trenching - no welding required - just uses your thumb circuit.
Perfect for demolition, building rock walls, clearing, and more.
TOFT Grapple Bucket
A bucket divided into 2 parts including a jaw connected to the main part to create opening and closing, making the bucket convenient in grabbing materials. Applied Size: Suits 1 to 50 tons’ excavator. (Could be customized for larger tonnage). Characteristic: Connected with a hinge, the 2 parts could create a jaw-like function that makes sure that the materials could be held tightly and moved away in a most efficient and energy-saving way. Features & Benefits: Materials: High strength allo...
WATCH THE VIDEO FOR THIS EXACT FACTORY TOFT BUILT JUST RENAMED BUCKET THAT THEY WANT $12000.00 FOR
Located Our Yard  Cambridge Narrows Nb
Please Call or Text or  WhatApp to Frank 604-476-7777
Take it for $6,000.00
Buckets:
Excavator Buckets
Hydraulic Attachments:
Grapples
Quick Couplers:
Pin Grabber Couplers
Fuel Type Diesel
Year of Vehicle Registration 2024
