Menu
Quick Eze Links
**** SOLD **** ESKRIDGE 12000 FOOT LB 2 SPEED AUGER / ANCHOR DRIVE C/W LONG HOSES AND 24 INCH AND 30 INCH AUGER ALSO AVAILABLE
Posted Date: May 1st, 2024 at 08:52 AM
0.0 star
Price: 5000.00 Negotiable
ESKRIDGE 12000 FOOT LB AUGER / ANCHOR DRIVE C/W LONG HOSES FOR TRUCK CRANE OR CRANE ETC
LOW HOUR USE UNIT FOR $5000.00
HAS SWIVEL TOP MOUNT - WAS USED ON A CRANE TRUCK SO HAS 30-50 FEET OF DUAL HOSES INCLUDED
TAKE IT FOR $5000.00 for bare drive - can supply the two augers that are shown with it for $7,000.00
77 Anchor Drive Drive Head – Anchor Drive, Double Planetary, Output Torque, 6,500 to 12,000 FT.-LB, Two-Speed, Automatic Kickdown, Maximum System Pressure: 2,500 PSI.
The 77 Series Anchor Drive, is a high-efficiency, heavy-duty, two-speed, double planetary drive that gives the operator ease of control in operation.
Ideal for use in the rental market. This unit features a 19,000 lb shaft pressure load, 21,000 lb. Shaft pullout load with a maximum system pressure of 2,500 psi and a maximum input speed of 3,000 rpm. Output shaft options include 2″, 2-1/2″, or 2-5/8″ hex.
Augers made to make your posthole digging, footings, shrub and tree plantings easy and efficient.
In construction applications, these diggers are suitable for mounting on skid steers, backhoes, and excavators, for increased job site mobility and efficiency over traditional methods.
Specifications
Rated Output Torque 12,000 Ft. Lbs.
Maximum System Pressure 2,500 PSI
Output Shaft 2", 2 1/2" or 2 5/8 HEX
Shaft Pullout Load 15,000 Lbs. / 6,800 Kg.
Shaft Pressure Load 15,000 Lbs. / 6,800 Kg.
Bail Boss Diameter 1 In. / 25.4 mm
THESE ARE IN OUR YARD IN LANGLEY BC - WILL SHIP WE GET GREAT RATES AND SERVICE OR PICKUP OR ARRANGE YOUR OWN SHIPPING
