Menu
Quick Eze Links
(sold) $55K 2023 OKADA TOP150 - 3000 FT-LBS CLASS HAMMER/ROCK BREAKER
Posted Date: Apr 30th, 2024 at 07:28 AM
0.0 star
Price: 25000.00
O HOURS SINCE OKADA FACTORY SHOP REBUILD - RESEAL - NOW CONSIDERED A 2023 HAMMER BY OKADA
LOW HOUR MINT CONDITION HAMMER - O HOUR SINCE RESEALED BY OKADA AMERICA C/W NEW FACTORY PISTON AND COMPLETE RESEAL - THEY STATED IT WAS TO GOOD TO SANDBLAST - SEE INVOICE IMAGE 4 FOR $10,000.00 USD INVOICE PLUS SHIPPING TO AND FROM THEIR OREGAN FACTORY
THIS HAMMER HAS 6 MONTHS OKADA NORTH AMERICA WARRANTY STARTING THE DAY YOU RECEIVE THE HAMMER
NOTE THESE ARE QUALITY JAPANESE HIGH QUALITY DEMOLITION ATTACHMENTS - NOT KOREAN KNOCK OFFS LIKE LABOUNTY OR STANLEY OR MORE THAT SHEARFORCE AND OTHERS DEALERS RE-BRANDS AND SELLS - THAT YOU FIND LASTS AT THE MOST 6 MONTHS
THIS WILL SHIP DIRECTLY FROM LANGLEY BC YARD TO BUYER WE GET GREAT RATES AND SERVICE
WE GET GREAT RATES AND FAST SERVICE - OR WILL SHIP ON BUYERS ACCOUNT
TAKE THIS UNIT FOR $25,000.00 WHICH IS ALMOST 1/2 PRICE OF NEW AND HAVE WORKING TOMORROW C/W TWO POINTS 1 NEW OTHER MINT ORIGINAL POINT
FRANK RAYNER 604-476-7777
Okada’s medium-class breakers are available in a wide range of designs, from those specifically engineered to provide maximum impact energy for the toughest rock applications to others suited for a combination of concrete and rock breaking with the potential for faster blow speeds.
Precision machining processes and strict Okada quality control are used to produce all main breaker components. There is no need for complete assembly replacements and the use of high-precision parts means economical, labor-saving rebuilds of your Okada breaker.
Breaker brackets are made of heavy gauge high tensile steel plates and are designed to give maximum protection to the breaker body and dissipate heat while making it easier to access the equipment during daily maintenance inspection.
Okada bushing designs, a special heat treatment process, and individually lubricated bushings enhance the service life of worn parts.
Similar models may be shown in addition to the featured model. Equipment may be shown with options. Specifications are subject to change without prior notice.
OKADA WEBSITE FOR THIS HAMMER (copy and paste) : https://okadaamerica.com/en/top150
OKADA PDF BROCHURE FOR THIS HAMMER : https://okadaamerica.com/dl-9780/TOP%20Brochure%207-2021.pdf
Technical Data
IMPACT ENERGY CLASS 3000 ft-lb / 4068 JOULES OPERATING WEIGHT 3000 lbs / 1361 kg OIL FLOW 30-35 gpm / 114-132 lpm FREQUENCY 600-750 bpm L-mode OPERATING PRESSURE 2030-2620 psi / 140-180 bar MECHANICAL ENERGY 42-63 hp / 31-47 kw MECHANICAL ENERGY AVG 52.5 hp / 39 kw UNIT WORKING LENGTH 94 in / 239 cm TOOL DIAMETER 4.8 in / 122 mm TOOL WORKING LENGTH 24 in / 610 mm CARRIER WEIGHT RANGE 28-42 lbs. / 13-19 M ton
2020 OKADA TOP150 - 3000 FT-LBS CLASS HYDRAULIC BREAKER FACTORY RESEAL
LOW HOUR MINT CONDITION HAMMER - O HOUR SINCE RESEALED BY OKADA AMERICA C/W NEW FACTORY PISTON AND FACTORY RESEAL TO NEW SPECIFICATIONS
FRANK RAYNER 604-476-7777 https://www.youtube.com/watch?v=_9Aib30B774
ALSO, CHECK OUT OUR FRESH REBUILT OKADA 7500 FT LB HAMMER IN MY OTHER ADS
