Menu
Quick Eze Links
(Sold) $125,000.00 Terex Schaeffer Heavy Duty Dual DrumCustom-Built Concrete - Rock - Shale - Frozen Ground Grinder
Posted Date: Jul 4th, 2024 at 06:58 AM
5.0 stars
Price: 40000.00 Negotiable
 $125,000.00 Terex Schaeffer Heavy Duty Dual Drum Custom-Built Grinder
Specifications:
  • Price: $40,000.00 (originally $125,000.00, save $85,000.00)
  • Condition: Excellent, used on one job before COVID-19
  • Applications: Concrete demolition, tunneling, rock profiling, sandstone, shale, frozen ground trenching
  • Features:
    • Depth protection limiter guard for extremely hard concrete with rebar and hard rock scaling
    • Produces 3-4 times more volume per day than a hydraulic breaker
    • Lower cost and noise volume
    • Produces a finished product ready for use as road base or fill without further processing
  • Inclusions:
    • Excellent  picks (teeth)
    • Low-hour unit
    • 100 mm front and rear pin bosses
    • 14.2 inches between the ears
    • Had water misting system installed for dust suppression - just add pressurized water
Compatibility:
  • Fits any pin grabbers that take 100 mm front pins with 14.2 inches between the ears
  • Can be bushed down to 90 mm to fit any 250-350 class excavator
Specifications:
  • Hydraulic input power: 160 HP
  • Oil flow rate required: 66 - 106 gpm
  • Cutting head width: 47.2 inches
  • Weight: Approximately 4530 lbs with pin-on or pin grabber top mount plate with 100 mm pins
  • Recommended excavator weight: 66,000 - 100,000 lbs (third member mounting) will work on 240 + Class With Caution
Fields of Application:
  • Canal and pipeline construction
  • Landscape gardening
  • Bioremediation/soil mixture
  • Quarrying
  • Sensitive areas
  • Road construction
  • Tunneling and mining
  • Building renovation and demolition
Additional Information:
  • Terex Schaeffer has been manufacturing cutting-edge machinery for over 40 years.
  • The grinder includes various hydraulic motors and cutting heads for optimum adjustment to operating conditions.
  • The product range includes seven types of transverse cutting units with hydraulic drive powers of 30 HP to 200 HP.
  • Special applications include cutting drums and slot cutting drums in various widths and diameters, drums for cutting tree stumps, and anti-dust systems for indoor operations.
Advantages of Cutting Technology:
  1. Extremely economical
  2. Extremely accurate cut
  3. Low vibration
  4. Low noise
  5. Suitable for underwater operations
  6. Low maintenance
  7. Suitable for narrow and deep trenches
  8. Recycling of excavated material
Contact Information:
  • Frank: 604-476-7777
Additional Resources: (copy and paste)
https://youtu.be/rSleaL-FoCo
https://youtu.be/BdzFNabFKQ4
We can supply trucking anywhere in North America except Mexico and offer great rates.
4o
Factory or Website Url http://media.voog.com/0000/0039/4210/files/ucm03_012855.pdf
Fuel Type Diesel
Transmission Automatic
Anonymous Dec 6th, 2024 at 05:31
ok,............m.
